2000 Dodge Ram Headlights
176,000 MILES • 6 CYL • 4WD • AUTOMATIC
ALLCOMZ
Headlights will only work when the steering wheel has been moved all the way up. Also radio controls in steering wheel do not function properly. Any suggestions?
Dec 12, 2008 at 1:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
It sounds like you have loose wiring in the steering column. Check all wiring in steering column to ensure they are not faulty/loose.
Post results and I will follow up.
Thanks for using 2carpros.com!
Dec 12, 2008 at 2:05 AM
