engine would not start so i banged on the gas tank to rattle the fuel pump...ten it started so i figured i would change the fuel pump....i put a test light on the fuel pumps wiring harness while the tank and pump was out from under the truck...and the light would go on when i would turn the key...then i would turn the key off and try it again and it wouldnt turn on....anyway i installed the fuel pump and tank...truck started right away....went for a drive threw some fuel in the tank and it wouldnt re-start at the gas station...i think the fuel relay is ok...any suggestions??
Feb 25, 2010 at 3:55 AM
