[quote:37780dc297="JamesJ"][quote:37780dc297="BMRFIXIT"][quote:37780dc297="JamesJ"]Electrical problem
2000 Dodge Ram V8 Two Wheel Drive Automatic 90000 miles
Yes what does code P0204 Injector Circuit Malfunction Cylinder 4 mean? What would have to do to fix it? It started jumping and shaking about 15-20 minutes after I filled my truck up & check engine light came on. Thank You[/quote:37780dc297]
If its bad gas you would see more than one cylinder misfire
I wouldn’t put it off
I’ll still check the fuel
but its an injector problem
1st check if that injector is pulsing if so the injector no good[/quote:37780dc297]
Thank You
How do I tell if that injector is pulsing?[/quote:37780dc297]
unplug it use a light check if it flash with engine running
they sell a tester for it
its like a small light plugs in instead of the injector
Jan 20, 2008 at 7:45 AM
