2000 Dodge Ram Code Diagonstics
JAMESJ
  • 2000 DODGE RAM
  • V8
  • 90,000 MILES
Yes what does code P0204 Injector Circuit Malfunction Cylinder 4 mean? What would have to do to fix it? It started jumping and shaking about 15-20 minutes after I filled my truck up & check engine light came on. Thank You
Sunday, January 20th, 2008 AT 9:59 AM
BMRFIXIT
  • 19,053 POSTS
If its bad gas you would see more than one cylinder misfire
I wouldn’t put it off
I’ll still check the fuel
but its an injector problem
1st check if that injector is pulsing if so the injector no good
Sunday, January 20th, 2008 AT 10:17 AM
JAMESJ
  • 5 POSTS
1st check if that injector is pulsing if so the injector no good[/quote:db5b0f929f]
Thank You
How do I tell if that injector is pulsing?
Sunday, January 20th, 2008 AT 2:45 PM
BMRFIXIT
  • 19,053 POSTS
1st check if that injector is pulsing if so the injector no good[/quote:37780dc297]
Thank You
How do I tell if that injector is pulsing?[/Quote:37780dc297]
unplug it use a light check if it flash with engine running
they sell a tester for it
its like a small light plugs in instead of the injector
Sunday, January 20th, 2008 AT 3:45 PM
MOPARTECH9423
  • 25 POSTS
You can check the resistance of the injector using an ohm meter. With the injector unplugged check the resistance across the injector it shouldn't be more than 12 ohms. Also check the terminals in the injector connector and make sure they are not spred. I doubt your gas fill up has anything to do with your problem becuase this code if for electrical integrity of the circuit.
Sunday, January 20th, 2008 AT 3:58 PM
JAMESJ
  • 5 POSTS
Thank You I'm gonna try that
Sunday, January 20th, 2008 AT 5:08 PM
