2000 Dodge Ram Blowing Cold Air
175,000 MILES • V8 • 2WD • AUTOMATIC
WANNER54
When I have my heater turned all the way up it is only blowing cold air. It will not get even warm
Oct 20, 2009 at 5:50 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please tell me your specific model….R1500, R2500 etc and what is the engine size in liter and the 8th digit of your VIN?
Oct 20, 2009 at 9:47 AM
JSWAIN
  • 24 POSTS
Could be something else, but if problem started suddenly, the thermostat is probably stuck.
Oct 20, 2009 at 3:47 PM
WANNER54
It did happen suddenly. We used the heater earlier in the week and then from Thrursday through Sat only the AC and then Sunday morning is when we turned the heater back on and it was blowing only cold air.
When we went out and tested it last night its like it is only letting the air conditioner blow cause the compressor was dripping water after we shut it off. Could the switch be faulty or wold the thermostat being stuck cause this?
Oct 21, 2009 at 6:29 AM
JSWAIN
  • 24 POSTS
Thermostat would not cause condensation on compressor. Could possibly be in the switch. Does engine temp gauge read normal? If so, probably not the thermostat. May have to let one of the staff guys answer.
Oct 21, 2009 at 6:38 AM
