2000 Dodge Ram battery drain
160,000 MILES • V8 • 4WD • AUTOMATIC
BRYANT71
I have a question about a battery drain, I have an intermittent slow battery drain. It takes about 3 days to drain the battery if you dont drive the vehicle i have replaced the battery with a red top and put a high output alternator on the vehicle. I hooked a meter to the battery and could see the drain it was minimal but more than it should be even with the internal memory pulling, i then pulled every fuse and could not get the drain to stop. The truck will sometimes be fine for months no problem after weeks of not driving it. I was thinking maybe the voltage regulator but i dont know where to go next , please help
Jun 22, 2010 at 8:59 PM
  • 75,988 POSTS
Disconnect the alternator if the draw is no longer there bench test the alternator if its continues unplug all the wiring connector of the computer and see what happens
Note: The computer controls the alternator field generation the short could be there
Jun 22, 2010 at 9:35 PM
