2000 Dodge Ram 4 wheel drive
2000 DODGE RAM
157,952 MILES • V8 • 4WD • AUTOMATIC
CAROL STEWART
4wheel drive does not go into gear,when in 2 wheel drive there will be a harmonic like sound going from not so loud to louder then stopping then doing it again.this will go on for miles then quit.this is allot more prone in the cold.if i have the shifter in 4 wheel drive this noise does not happen.there is a new actuateron this truck also new hub bearings and u-joints.the noise i here is not grinding noise and sounds like it is on the drivers side.according to the dash the 4 wheel drive is engaged but is not.
Jan 9, 2010 at 10:08 AM
  • 110,244 POSTS
Check the 4wd vacuum actuator on the front axle.
Jan 14, 2010 at 2:54 AM
