1999 Dodge Ram rotors
140,000 MILES • V8 • 4WD • AUTOMATIC
DAVE HAZEN
why are the rotors sticking i took everything off and still wont release
May 4, 2010 at 3:30 PM
BLUELIGHTNIN6
  • 16,542 POSTS
rotor may stick from brake heat, try banging it loose by hitting in between lugs with rubber headed mallet
May 4, 2010 at 3:33 PM
DAVE HAZEN
no it did not work please help!!
May 4, 2010 at 3:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
front or rear rotors?
May 4, 2010 at 4:05 PM
DAVE HAZEN
IT IS FRONT PASSENGERS SIDE
May 5, 2010 at 1:24 AM
BLUELIGHTNIN6
  • 16,542 POSTS
okay check this out for me, does it have 5 lug studs or 8 lug studs on it? you may have a cotter pin holding the rotor hub nut on, that nut will need removed if equipped. with 8 stud style, the rotor and hub is removed as an assembly.
May 5, 2010 at 5:15 AM
