1999 Dodge Ram rotors
DAVE HAZEN
  • 1999 DODGE RAM
  • V8
  • 4WD
  • 140,000 MILES
Why are the rotors sticking I took everything off and still wont release
Tuesday, May 4th, 2010 AT 10:30 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Rotor may stick from brake heat, try banging it loose by hitting in between lugs with rubber headed mallet
Tuesday, May 4th, 2010 AT 10:33 PM
DAVE HAZEN
No it did not work please help!
Tuesday, May 4th, 2010 AT 10:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Front or rear rotors?
Tuesday, May 4th, 2010 AT 11:05 PM
DAVE HAZEN
IT IS FRONT PASSENGERS SIDE
Wednesday, May 5th, 2010 AT 8:24 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay check this out for me, does it have 5 lug studs or 8 lug studs on it? You may have a cotter pin holding the rotor hub nut on, that nut will need removed if equipped. With 8 stud style, the rotor and hub is removed as an assembly.
Wednesday, May 5th, 2010 AT 12:15 PM
