1999 Dodge Ram Replaced the battery and alternator will not
201,157 MILES • 6 CYL • 2WD • AUTOMATIC
ADAMBUCS1
I have replaced the battery as well as the alternator. When I turn the key, I hear the fuel pump turn on, I have power, and the truck will turn over but will not start. Any ideas?
Dec 25, 2009 at 1:00 AM
JDL
  • 16,098 POSTS
Welcome to the forum, Have a helper crank it, while you check for spark at the plugs. Also, check for trouble codes. You may be able to get some codes by the mil method. you turn key just till dash lites come on, no further. You cycle the key, on--off, on--off, on, then the mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes. An example, code 24 would be two quick flashes, a pause, 4 quick flashes.
Dec 25, 2009 at 3:43 AM
