1999 Dodge Ram rear wheels won't turn when rear end is lift
1999 DODGE RAM
149,000 MILES • V8 • 4WD • AUTOMATIC
CHRISTOPHER_BOWER1
I replaced leaky wheel bearings on the rear drums reciently, and when I put everything back together, the rear wheels won't spin when it is still jacked up. It will move but it feels like the emergency brake is still engaged, even though you can see the tension release when the e-brake peddel is engaged and disengaged.
Apr 7, 2010 at 6:27 AM
  • 110,240 POSTS
WHen you replaced the axles, are you sure the splines aligned properly? Can you turn the wheel by hand? If you remove the drum, can you spin the axle?
Apr 12, 2010 at 1:42 PM
