1999 Dodge Ram Piston 1 misfiring
128,000 MILES • V8 • 4WD • AUTOMATIC
JSWILSON
Hello, I have a 99 dodge ram 1500, v8 5.9l. The check engine light is on, so I had the code ran, it said that piston 1 is misfiring. However, when we left the code reader on and ran the truck, the misfire goes away at a hirer rpm. So it is only happening at an idle. What do you think?
May 2, 2008 at 9:35 AM
  • 75,988 POSTS
A misfire in a specific cylinder should lead you to check the spark plug, compression and injector for that given cylinder
May 2, 2008 at 11:03 AM
