1999 Dodge Ram not cooling good
96,000 MILES • V8 • 4WD • AUTOMATIC
GARNER1
air is cold in the morning then it never gets colder than what outside temp.is
Jul 8, 2010 at 1:37 PM
  • 110,251 POSTS
Was the system ever serviced? Is the AC compressor cycling?
Jul 8, 2010 at 2:27 PM
GARNER1
yes everything was changed out last spring, drier,evaporater, and hoses.compressor cycles good.checked everything under dash
Jul 12, 2010 at 3:00 PM
  • 110,251 POSTS
If everything is working, then I would recommend checking the blend air door. Something tells me it isn't working properly.
Jul 16, 2010 at 2:48 PM
GARNER1
[quote:26fe0c28ab="Jacobandnickolas"]If everything is working, then I would recommend checking the blend air door. Something tells me it isn't working properly.[/quote:26fe0c28ab]blend air door is working properly,already checked.could it be the low preesure switch?
Jul 18, 2010 at 12:52 PM
  • 110,251 POSTS
Did you have an additional question?
Jul 19, 2010 at 3:04 PM
