1999 Dodge Ram Noise
202,800 MILES • V8 • 2WD • AUTOMATIC
TAVITA
Dirving foward and reverse I've been hearing a windding sound coming from the back this has been going on for more than tow years and the souynd is starting to get a bit louder. Only makes sound when truck is moving. No mayjor prob yet...I hope. It's a Ram 1500 just to add. Thx for any and all the help.
Feb 27, 2009 at 1:50 AM
  • 110,251 POSTS
Hi:
Start by making sure the rear differential is full and the gear lube is clean. If it isn't fill it or have is serviced. If that doesn't take care of the problem, check the seal where the yoke comes out of the differential for leaks which may indicate a bearing problem. If nothing, it could be an axle bearing going bad.
Feb 27, 2009 at 12:48 PM
