1999 Dodge Ram No power to coil
159,000 MILES • V8 • 2WD • AUTOMATIC
GARY COPE
I have a 99 ram 2500 with a 5.9. The truck died while driving without warning and hasn't restarted since. I have replaced the cam sensor, the crank sensor, the coil and the PCM. I still cannot find any voltage to the harness that supplies power to the coil. What could I be missing?
Jun 19, 2010 at 2:15 AM
  • 75,988 POSTS
Inspect and test the ASD relay
Jun 19, 2010 at 2:22 AM
GARY COPE
[quote:361e7ac2dd="rasmataz"]Inspect and test the ASD relay[/quote:361e7ac2dd]Did that this morning before writing the question, the relay is fine. It switches and shows the correct continuity under power. The panel it plugs into shows no power to the terminal that corresponds to terminal 30 of the relay. This should be constant hot. The switched power terminal is fine and reads 12.54 volts with the key on.
Jun 19, 2010 at 5:49 PM
