1999 Dodge Ram NO HEAT
158,000 MILES • V8 • 4WD • AUTOMATIC
STEVEOZ
I REPLACED THE THERMOSTAT AND ALWAYS FLUSH MY COOLING SYSTEM. BOTH HEATER HOSES ARE WARM.HEATER CORE IS NOT LEAKING AND NO SMELL OF COOLANT.I MOVE THE TEMPERATURE CONTROL KNOB AND IT SOUNDS AS IF THE BLEND DOOR IS WORKING! COULD THIS BE THE ACTUATOR AND DO I NEED TO PULL THE DASH OUT OR MAYBE JUST THE GLOVEBOX? AND WHAT REPAIR MANUAL CAN I USE THAT WILL SHOW ME ALL THE DETAILS ON THIS REPAIR.THANKS
Dec 16, 2009 at 5:14 AM
  • 110,246 POSTS
Double check the blend door. As far as a manual, chances are you will need pictures from a dealer's manual. They offer mitchell online on this webpage. You can check it.
Dec 18, 2009 at 1:02 AM
