1999 Dodge Ram no bu5
105,200 MILES • V8 • 2WD • AUTOMATIC
DODGERAM1999
the odometer says no bu5 and the truck won't start. What is the problem and what does no bu5 mean?
Apr 25, 2009 at 9:13 AM
BMRFIXIT
  • 19,053 POSTS
No power to the PCM
check wiring harness
bad PCM
wiring more likely
check harness 1st
Apr 25, 2009 at 9:23 AM
DODGERAM1999
Could it be my dash cluster wiring connector may be lose or could it be the crank sensor but i get no codes when i hook it up to a scan tool.
Apr 25, 2009 at 10:17 AM
BMRFIXIT
  • 19,053 POSTS
can you comunicate with the PCM ?
Connect jumper wire between ground and DLC connector terminal No. 11 (White/Black wire). Turn ignition off. Remove instrument cluster. Using external ohmmeter, measure resistance between ground and instrument cluster connector C1 terminal No. 9 (White/Black wire). If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair open White/Black wire.
Disconnect jumper wire. Connect jumper wire between ground and DLC connector terminal No. 3 (White/Black wire). Measure resistance between ground and instrument cluster connector C1 terminal No. 10 (Violet/Brown wire). If resistance is less than 5 ohms, replace instrument cluster. If resistance is 5 ohms or more, repair open Violet/Brown wire.
Apr 25, 2009 at 5:16 PM
