1999 Dodge Ram location of the turn signal flasher unit
1999 DODGE RAM
256,153 MILES • V8 • 2WD • AUTOMATIC
CORY L. HOUSER
trying to replace the turn signal flasher on a 1999 dodge ram van 3500 v8 3.2. Book says it is on or behind the fuse block or behind the glove compartment. Of course the dealer has no idea. Can you help me?
Dec 27, 2007 at 10:04 AM
STEVELASSERE
The turn signal flasher is under a triangular panel that pulls off from the drivers end of the dash board. You need to open the drivers door all the way and you will see the panel at the end of the dash board. Pull the cover off and the flasher will be the blue plastic relay about 1" square at the lower end of the fuse panel. Pull it out and replace it. About $30.00.
Dec 5, 2012 at 5:31 AM
