i was driving down the road and my truck started to loose power at larger throttle openings and then just died like it ran out of gas. it will not start again and tries to fire at wide open throttle. i have spark. i checked timing and it is good. i have 46 psi fuel pressure at the rail when i turn the key on. the motor only has 160 000 km. the motor has good compression. it has newer plugs.
Jan 25, 2010 at 8:43 AM
