1999 dodge pick-up,ram 1500,4WD,5.9L,automatic transmission:
I removed and installed an instrument cluster,speedometer and guages,from my pick-up.I reconnected the PRNDL cable on the position arm on the steering column.When i move the shift lever to the park position on the PRNDL indicator,the pointer moves and displaces in the opposite direction.How do i correct the problem?how do i route the PRNDL cable around the steering column?I'm not sure i routed it correctly.
Aug 12, 2010 at 10:28 AM
