1999 Dodge Ram I think my timing chain is off a link
SHALONMCMILLEN
  • 1999 DODGE RAM
Engine Performance problem
1999 Dodge Ram V8 Two Wheel Drive Automatic
I replaced the crank shaft and crank sensor, timing chain and timing gear, cam shaft and cam shaft sensor, spark plugs. The truck is running like if is missing on injector #4. Everything is set according to specs but I was wondering if the timing chain could be off 1 link to cause the engine to miss.
Saturday, December 6th, 2008 AT 11:20 AM
  • 109,885 POSTS
Hi:
Is it a constant miss? If the timing chain is off, the engine will run very poorly (if at all), but I doubt it would only be one cylender causing the problem. Why do you think it's #4?
Monday, December 8th, 2008 AT 1:35 PM
