1999 Dodge Ram help me please
1999 DODGE RAM
165,000 MILES • V8 • 4WD • AUTOMATIC
MSMITH912
99 model dodge ram 4x4. at 3000 rpm my truck loses all power. i replaced plug wires and battery terminal ends. it starts and idols just fine but when i get into it or when i pull a trailer, it just loses all its power. what could this be attributed to?? thank you
Sep 9, 2008 at 9:50 AM
BMRFIXIT
  • 19,053 POSTS
check for fuel pump and fuel pressure
check O2 sensors
Sep 9, 2008 at 12:04 PM
HQUAST
Loosen the exhaust at the engine and see if the power
has come back under load, if it did you have a plunged
exhaust or converter.
As a mechanic for over 30 years i have seen 50 to 60
like this.
Sep 14, 2008 at 1:25 PM
KEVIN12881
  • 336 POSTS
also check incorrect grade of fuel, ignition timing incorrect, Carbon build up in combustion chambers, incorrect spark plugs (old or gap),ESC system, faulty distributer cap, dirty air filter, fault ignition coil(s), brakes binding, automatic trans fluid, EGR system, low or uneven cylinder compression, air (vacume) leak at intake manifold......Please update when problem is solved
Sep 14, 2008 at 1:45 PM
