1999 Dodge Ram Headlights not working correctly
118,000 MILES • V8 • 4WD • AUTOMATIC
NE1LOST
My dilemma is that my headlights are on brights and they not shut off unless I turn the lights off altogether. The drivers side dim does come on but yet the other does not, when you try to turn the dims on. My dash indicator light just goes dimmer and does not ever shut off either. My drivers side taillight works fine til I hit the brakes and then it goes really dim when the running lights are but works fine when they are off. I have replaced the multi function switch and the quad beam relay. The grounds seem to be in good shape.
Oct 22, 2008 at 10:29 AM
MASTERTECHTIM
  • 4,750 POSTS
i would definitely suspect a bad ground, try adding a ground to the ground and see if the problem goes away.
Oct 22, 2008 at 1:51 PM
NE1LOST
I tried that earlier in the day and that didn't work. So I also looked at the headlights and made sure they were hooked up right and the right ones.
Oct 22, 2008 at 9:44 PM
