Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Ram
Fuel System
fuel pressure
What is the correct fuel pressure?
1999 DODGE RAM
72,000 MILES • V8 • 4WD • AUTOMATIC
KELDEY
MEMBER
1 POST
what is the correct fuel pressure for my 1999 dodge ram 15000 5.2L 4-wheel drive pick up.
Apr 2, 2009 at 2:09 PM
OBXAUTOMEDIC
Experienced Mechanic
Fuel pressure at Idle is between 44 & 54 psi.
Here is a guide to help you run the test with instructions over your truck in the images below.
Check out the images (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
Apr 2, 2009 at 2:19 PM
The fuel pressure should be 44-54psi as specified
Apr 2, 2009 at 2:22 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
