1999 Dodge Ram Error Codes
150,000 MILES • V8 • 2WD • AUTOMATIC
RAM1500_2X4
My truck has a modified air intake and exhaust which have caused the oxygen sensor to send the following error codes:
P0132
P0135
P0138
P1757
These errors won't let me pass the smog test, and the "check engine" light is always on. What can I do to fix it?
Mar 5, 2009 at 10:46 AM
MERLIN2021
  • 17,250 POSTS
The first three codes are 02 sensor codes for bank 1 but for a truck with 150,000mi. change all four sensors. p1757 is a tranny code, governor pressure above 3 psi when 0 psi is requested. Try replacing the 02 sensors and reset the MIL.
Mar 5, 2009 at 11:11 AM
