when i start the truck it idles smooth with an occasional missfire. when i rev up the engine to high rpm's it won't missfire at all. also when starting at a dead stop it will missfire until into the higher rpm's and then run smooth until it drops into overdrive where the rpm's are low again. i just bought this truck so i am not really sure what the problem may be. the past owner said the fuel pump and plugs are new.
Mar 24, 2010 at 12:29 PM
