1999 Dodge Ram engine bogs at 2000 rpm's
143,000 MILES • V8 • 2WD • AUTOMATIC
BNOLTE77372
MY TOP RAD HOSE SPRUNG A LEAK THAT SPRAYED ONTO THE FRONT OF THE CARB AND MAP SENSOR.
HOSE AND MAP SENSOR CHANGED, AND ENGINE STARTS AND IDLES FINE UP TO ABOUT 2000 RPM, THEN BOGS DOWN BAD. LET OFF THE GAS, AND IT IDLES FINE AGAIN.
Feb 16, 2010 at 9:58 AM
  • 110,251 POSTS
Has the check engine light come on? Have you checked to make sure there are no vacuum leaks? Also, check to make sure the catylatic converter isn't plugged.
Feb 19, 2010 at 2:45 AM
