1999 Dodge Ram ENGINE
DENNIS SOUDERS
Engine Mechanical problem
1999 Dodge Ram V8 Four Wheel Drive Automatic
TRUCK STARTS AND RUNS GOOD FOR 15 MIN THEN SHUTS OFF AND WILL NOT RUN AGAIN UNTILL COOLS DOWN
Jan 23, 2010 at 1:59 AM
  • 110,246 POSTS
WHen this happens, have you checked for spark and fuel to the engine? One will be missing and I need to know which one to direct you. Here is a how to for checking both:
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know which is missing so I know what to have you check. Also, let me know if the check engine light is on.
Jan 26, 2010 at 1:31 PM
