1999 Dodge Ram Dashboard
18,000 MILES • V8 • 2WD • MANUAL
BHEVRIN
My dashboard is breaking. It's breaking into pieces. It's the whole dashboard (on top).
Is this a recall item? What are my options?
Aug 29, 2008 at 3:15 PM
BMRFIXIT
  • 19,053 POSTS
I don’t believe it is
not seen it but will for sure will check
Aug 29, 2008 at 11:31 PM
DHOPKINS
It is my understanding the in the 98 thru 01 model ram 1500 this is a common problem that the dash will crack in to many peices and then cause hugh holes. Dodge will not admit this is a defect or a common problem but there are hundreds of people with this exact problem. I heard that it is because Dodge was able to get cheapper material but the quality was also less. The replacement from dodge is about $400 to $500 and then you have anywhere from #300 to $600 in Labor. The other option that i know of is to buy a cover and install it. I hope that this helps.
Sep 2, 2008 at 2:36 AM
