1999 Dodge Ram Clunking sound
127,000 MILES • V8 • 4WD • AUTOMATIC
KLEINES
When I'm in 2WD, there is a clunking sound that speeds up as I speed up. I put it into 4WD last night and the clunking sound went away. The sound is pretty loud and I'm wondering what the cause is?
Thank you!
Dec 11, 2008 at 2:04 AM
RACEFAN966
  • 5,029 POSTS
FIrst off what have you checked and haven't checked? Do you have an idea of where it sounds like it is coming from? How are the rear u-joints (on the rear driveline)? Does it have a carrier bearing on the rear driveline and if so is there alot of play in it? Get back to me with what you know and we will go from there. Thanks and have a great day.
Dec 11, 2008 at 2:19 AM
KLEINES
I haven't been under there to check anything so far. The noise seems to be coming from the front of the truck.
Dec 11, 2008 at 2:47 AM
RACEFAN966
  • 5,029 POSTS
Ok so I would check the driveline u-joints and the axle shafts for looseness first. Let me know what you find and we will go from there.
Dec 11, 2008 at 2:40 PM
