1999 Dodge Ram brake line splitter on rear axle
125,000 MILES • V8 • 2WD • AUTOMATIC
XPMAN
There is a splitter on the driver's side rear axle that sends brake lines to the left and right side wheels. There is also a black rubber hose (18" or so and about 1/2 dia.) that comes off the top of the splitter. It has a white plastic connector on the other end of it that looks like it's supposed to be plugged into something. I found this hose dragging on the ground when I pulled into the driveway. The clamp that held in place rusted through but I can't seem to find where this hose is supposed to connect to! There isn't any fluid leaking from it.
Mar 15, 2010 at 11:08 AM
  • 110,248 POSTS
Are you sure the rubber hose isn't a breather from the differential? THat is what you described. THere shouldn't be any rubber brake hoses on the rear brakes.
Mar 15, 2010 at 3:19 PM
XPMAN
It very could well be what you describe. I just know that one end is connected to the same "splitter" block for the brake lines. What is the breather hose used for exactly?
Mar 15, 2010 at 9:12 PM
  • 110,248 POSTS
It allows pressure to be released.
Mar 16, 2010 at 3:06 AM
