1999 Dodge Ram book time to replace oil pump
DAVID1958
1999 Dodge Ram V8 Two Wheel Drive Automatic
please advise book time to replace oil pump and procedure?
Aug 1, 2010 at 5:24 AM
  • 110,248 POSTS
The labor for replacing the pump is 1.8 hours on a 2wd. As far as the procedure, basically you need to remove the oil pan and then the pump just bolts on to the rear main bearing cap. It is a dirty job, but not that hard.
Aug 1, 2010 at 3:18 PM
