1999 Dodge Ram auto door locks
105,000 MILES • V8 • 4WD • AUTOMATIC
MIKECHADWELL
My battery recently died. I jump started my pickup and went and had the battery replaced. After this my automatic door openers do not work. (Press pad) Is there a reset I need to push?
Feb 25, 2008 at 4:19 AM
EPY
  • 19 POSTS
This happened to me once on my chevy mallibu.All i did was to take the battery terminals off and reset the computer. Or it may be a fluke but the batteries in your automatic door opener may be bad. try all the basics.Happy hunting(post your progress)
Mar 10, 2008 at 6:38 PM
EPY
  • 19 POSTS
I may have given you bad advice,I thought you meant your hand held auto door unlock. sorry.. an easy solution may just be your fuse.One door would be an electrical problem but both doors sounds like a fuse,If it still dont work check the connections were the door opens by the hinges,maybe the wires are pinched ,Or could be just dirt in the connections.
Mar 16, 2008 at 3:24 PM
