1999 Dodge Ram ac switching
SCOOBYWRU3
Air Conditioning problem
1999 Dodge Ram 6 cyl Two Wheel Drive Automatic
when ac is on the air blows from front panel to defrost. it only happens when driving up hill giving more gas
Sep 2, 2008 at 1:01 PM
EDDIE7644
  • 14 POSTS
I have a 1997 and had the same problem and believe it or not it was a pin hole leak in one of the tiny black hard hoses going into the firewall from the engine on the pass. side. The small hose is a vaccum that goes directly to your climate control.
Sep 18, 2008 at 2:46 PM
HQUAST
check the vacuum lines from the engine to the firewall .see if the hoses are cracked or disconnected.
you have a vacuum leak and should hear a hissing noise.
the system is designed to go to defrost when there is a lose of vacuum.
let us know what you find.
Sep 20, 2008 at 3:59 PM
