The ABS and Brake Light remain on
JKOLB
  • 1999 DODGE RAM
  • V8
  • 4WD
  • 72,000 MILES
The ABS and Brake Light remain on, Parking brake is not engaged, No visable leaks, Break fluid was low, it has been filled, lights remain on. Is there anything else I can check or is there anything that needs to be reset?
Monday, September 15th, 2008 AT 9:36 AM
MHENDROCK
Had the same issue with my 99 dodge ram, replace the rear wheel sensor on the rear end, really easy and fairly cheap, should solve your problem
Monday, March 1st, 2021 AT 12:41 PM
F4I_GUY
  • 3,302 POSTS
Jkolb,
Don't start replacing parts like mhendrock recommended. You first have to run through a diagnostic to determine what the problem is.
The parking brake light and ABS light is illuminated because you have an ABS fault. To retrieve the code, ground PIN 13 on the DLC connector underneath the driveside dash. The ABS and parking light will start flashing a code. This will then tell you what circuit has failed
