WHEN I AM DRING MY 99 RAM 4WD TRUCK,IT WILL JUST SHUT DOWN,LIKE YOU TURNED THE KEY OFF,IT WILL ONLY START AFTER IT COOLS DOWN,ITS BEEN DOING THIS FOR ABOUT A YEAR,SOMETIMES IT WILL RUN FINE FOR A WEEK TO A MONTH,THEN BLAM,JUST SHUTS DOWN,ALSO WHEN IT SHUTS DOWN,THE GAUGES DO NOT WORK,AND WHERE THE DIGITAL MILEAGE READING IS,IT WILL SAY... NO BUS...I TRIED REPLACING AND RELOCATING THE COIL,RAN FINE FOR MAYBE 2 WEEKS,THEN BLAM,IT DIED AGAIN...SO I REPLACED THE WATER PUMP,THERMOSTAT,AND FLUSED THE COLLANT SYSTEM,WORKED FINE FOR 2 DAYS,THEN DIED AGAIN THIS MORNING,THE TRUCK DOES NOT OVER HEAT,THE TEMP IS FINE,,I AM STUMPED,WHAT COULD BE CAUSING THIS PROBLE,ALSO IT WILL NOT SCAN ANY CODES,SYAS ALL IS NORMAL...BOB
May 27, 2008 at 2:23 AM
