engine stalls when step on accelerator fuel pressure is good tps checked out good map sensor checked out good any ideas?
Sep 27, 2010 at 12:18 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
WRENCHTECH
AUTOMOTIVE REPAIR CONTRIBUTOR
What did you use to test these things?
Sep 27, 2010 at 12:23 PM
KEITH C
MEMBER
i used a pressure tester for the gas and a volt meter for the sensors
Sep 27, 2010 at 1:22 PM
WRENCHTECH
You seem to have targeted the right sensors. Did you make sure the entire range was smooth with no glitches?
Sep 27, 2010 at 1:27 PM
KEITH C
MEMBER
the readings on the volt meter were smooth and right on the numbers according the haynes book that i have
Sep 27, 2010 at 1:39 PM
WRENCHTECH
Other than a severe vacuum leak I think it has to be related to one of those sensors. Maybe someone else will have some ideas here.
