Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Ram
Engine
Symptoms
Stall While Driving
engine stalls when step on accelerator?
1999 DODGE RAM
KEITH C
MEMBER
engine stalls when step on accelerator fuel pressure is good tps checked out good map sensor checked out good any ideas?
Sep 27, 2010 at 5:18 AM
WRENCHTECH
Experienced Mechanic
What did you use to test these things?
Sep 27, 2010 at 5:23 AM
KEITH C
MEMBER
i used a pressure tester for the gas and a volt meter for the sensors
Sep 27, 2010 at 6:22 AM
WRENCHTECH
You seem to have targeted the right sensors. Did you make sure the entire range was smooth with no glitches?
Sep 27, 2010 at 6:27 AM
KEITH C
MEMBER
the readings on the volt meter were smooth and right on the numbers according the haynes book that i have
Sep 27, 2010 at 6:39 AM
WRENCHTECH
Other than a severe vacuum leak I think it has to be related to one of those sensors. Maybe someone else will have some ideas here.
Sep 27, 2010 at 6:41 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
