Engine stalls when step on accelerator?
KEITH C
  • 1999 DODGE RAM
Engine stalls when step on accelerator fuel pressure is good tps checked out good map sensor checked out good any ideas?
Monday, September 27th, 2010 AT 12:18 PM
WRENCHTECH
  • 20,761 POSTS
What did you use to test these things?
Monday, September 27th, 2010 AT 12:23 PM
KEITH C
I used a pressure tester for the gas and a volt meter for the sensors
Monday, September 27th, 2010 AT 1:22 PM
WRENCHTECH
  • 20,761 POSTS
You seem to have targeted the right sensors. Did you make sure the entire range was smooth with no glitches?
Monday, September 27th, 2010 AT 1:27 PM
KEITH C
The readings on the volt meter were smooth and right on the numbers according the haynes book that I have
Monday, September 27th, 2010 AT 1:39 PM
WRENCHTECH
  • 20,761 POSTS
Other than a severe vacuum leak I think it has to be related to one of those sensors. Maybe someone else will have some ideas here.
Monday, September 27th, 2010 AT 1:41 PM
