1998 Dodge Ram will not start
FISHMAN435
Engine Performance problem
1998 Dodge Ram V8 Four Wheel Drive Manual
engine light came on then it died.it will not start.it has good spark and fuel pressure.
Oct 17, 2009 at 12:47 AM
  • 110,248 POSTS
You need to have the computer scanned to identify why it isn't starting. If the light is on, there is a code stored in the computer that will identify the problem. Also, if you are getting both fuel and spark, then either the fuel pressure is low, the injectores are not putting fuel into the cylender (try starting fluid) or the spark is too weak to burn the fuel.
Check both. Here is a how to for checking pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find. Also, most parts stores will lend or rent the tools needed to read fuel pressure and the check engine light.
Oct 22, 2009 at 3:47 AM
