1998 Dodge Ram Wet passenger side carpet
245,000 MILES • V8 • 2WD • AUTOMATIC
RRENTFREW
The passenger side carpet is always wet after driving. I live in florida and it has been a lot lately but there are visible signs of leaking, i.e. no rust or cracks. Also no antifreeze odor. Could this be coming from the a.c. and how can I fix it.
Aug 27, 2009 at 2:30 AM
  • 75,988 POSTS
Could be a clogged up drain tube or its leaking in from the outside somewhere-
Aug 27, 2009 at 3:50 AM
EGAR1861
I had the same problem and it took me forever to find the leak. I wound up pulling the right fender off (not as bad as it sounds just go slowly). I could not see the leak without pulling the fender. There was a gap in the cowl along the seam where it meets the firewall where the factory did not seal it correctly. A tube of silicone and the problem went away for good. Hope this helps.
Dec 12, 2009 at 4:24 AM
