1998 Dodge Ram Warning Lights
1998 DODGE RAM
ACHS65
Brakes problem
1998 Dodge Ram V8 Two Wheel Drive Automatic
The 'ABS' light and the 'Brake' light on the dash are both illuminated and stay on during vehicle operations. Is this a warning of some problem with the braking system? Please advise!
Feb 16, 2009 at 10:00 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You'll need a code scanner that can read ABS codes. ABS code readers are not generally available to the public. It's probably a bad wheel sensor, actuator or connector, but you can't possibly know what's wrong without the ABS code scanner.
Thanks for using 2CarPros.com!
Feb 16, 2009 at 10:24 AM
