1998 Dodge Ram turn signals
167,033 MILES • V8 • 2WD • AUTOMATIC
GREG GARDNER
I have replaced the switch on the steering wheel as well as the flasher I have checked fuses on the side panal by drivers side dash as well as fuse box under the hood and I have power in both spots and turn signals still dont work I did note that there was a short under bed of the truck and I fixed that i did notice about the time all of this that happened a little bit of smoke came out of the dask is it possible that the wiring harness were it runs in to the fuse box burnt lose there or would there be something else that could be burnt out
Jan 11, 2010 at 11:46 AM
GREG GARDNER
[quote:d4076e4a85="greg gardner"]Electrical problem
1998 Dodge Ram V8 Two Wheel Drive Automatic 167033 miles
I have replaced the switch on the steering wheel as well as the flasher I have checked fuses on the side panal by drivers side dash as well as fuse box under the hood and I have power in both spots and turn signals still dont work I did note that there was a short under bed of the truck and I fixed that i did notice about the time all of this that happened a little bit of smoke came out of the dask is it possible that the wiring harness were it runs in to the fuse box burnt lose there or would there be something else that could be burnt out[/quote:d4076e4a85]
Jan 11, 2010 at 11:49 AM
