1998 Dodge Ram Truck Shaking
150,000 MILES • V8 • 2WD • AUTOMATIC
NICOLE16
I have a 98 Dodge Ram that runs good My husband changed the U-joints, Tie rods ,drive shaft center support did a Tune up, and the Truck still shakes when we hit 45 mph it will start shaking alot only when we hit 45 mph when we hit 55 mph it will stop. It also will stop if we turn off the overdrive. The Gears all go in smoothly and never hesitate and we have know idea what the problem could be we have brought it to 5 Mechanics and everyone tells us something different. Please Help, Thanks
Sep 15, 2009 at 7:27 AM
DOCFIXIT
  • 18,828 POSTS
Torque convertor lock-up either clutch worn or fluid pressure loss.
Sep 15, 2009 at 7:33 AM
NICOLE16
Can a Clutch be replaced?? and how do you fix the fluid pressure loss? Thanks again
Sep 15, 2009 at 11:44 AM
DOCFIXIT
  • 18,828 POSTS
Need tests of pressure and solenoid operation to confirm. If that's the fault then trans removal is necessary and replacement of convertor and shaft seals.
Sep 17, 2009 at 1:12 AM
