1998 Dodge Ram timming
PISLE123
Engine Performance problem
1998 Dodge Ram V8 Two Wheel Drive Automatic
what should the timming be set at for this engine?
Jul 9, 2009 at 10:43 AM
BMRFIXIT
  • 19,053 POSTS
IGNITION TIMING
On all models, ignition timing is controlled by Powertrain Control Module (PCM). Ignition timing is nonadjustable.
DO NOT attempt to adjust ignition timing by rotating distributor.
NOTE:On Dakota 3.9L, 5.2L and 5.9L, Durango, Ram Pickup, Ram Van and Ram Wagon, if distributor is rotated, fuel system synchronization will be changed. If distributor is removed or rotated, check fuel system synchronization
Jul 10, 2009 at 9:24 PM
