1998 Dodge Ram Starting problems
146,000 MILES • V8 • 2WD • AUTOMATIC
WOLFY7774
Have a '98 Dodge Ram 1500 5.9 engine. I have a problem getting the ignition to fire. Checked the battery for full charge, it seems fine, replaced the ignition coil, following advice of a friend, but it did nothing to change the problem. About to try replacing the starter, and thought to ask her for advice.
Aug 16, 2010 at 5:06 AM
  • 110,248 POSTS
Is the starter turning the engine slowly? If not, it's fine. Have you checked fuel pump pressure?
Aug 16, 2010 at 4:45 PM
WOLFY7774
will giveit a try. Thanks
Aug 16, 2010 at 5:04 PM
  • 110,248 POSTS
If you need directions, let me know. Also, pay close attention to fuel pressure drop off when the key is turned off.
Let me know what you find. Also, was the starter turning slowly?
Aug 17, 2010 at 4:50 PM
WOLFY7774
The starter tested out fine. Think I'll probably remove the bed to get access to the fuel pump. It seems the lesser of two evils.
Aug 17, 2010 at 4:54 PM
  • 110,248 POSTS
Have you checked fuel pressure? I would do that before removing the bed.
Aug 17, 2010 at 6:44 PM
