1998 Dodge Ram Random/Multipe cylinder misfire Po300,PO302,
5,000 MILES • V8 • 4WD • AUTOMATIC
MICKMOORE
Can't figure this one out I've replaced wires,plugs,ingtion coil and I just bought capp and rotor if this doesn't work I don't know. I just replaced of the above 3 weeks ago and can't clear the codes
May 20, 2008 at 1:22 PM
  • 75,988 POSTS
P0300 is a Random Misfire code usually indicates a vacuum leak or bad fuel.
P0302 a misfire in a specific cylinder should lead you to check the spark plug, fuel injector and compression for cyl no.2
May 20, 2008 at 4:39 PM
