1998 Dodge Ram no spark
4JSFARM
Electrical problem
1998 Dodge Ram V8 Four Wheel Drive Automatic
check and no spark at coil or plugs should check for power at coil next??
Nov 7, 2009 at 10:19 PM
JDL
  • 16,098 POSTS
Welcome to the forum, yeah, check primary voltage to coil and injectors, engine cranking, dark green wire with orange tracer, should be hot. That voltage comes from the asd relay, that doesn't mean the relay is faulty, check the relay circuits for voltage and ground. The pcm grounds the relay, a common reason for no ground, the computer thinks there is a problem with the cam or crank signal circuit.
Nov 8, 2009 at 1:21 AM
