Then on my way home I lost power then stalled?
BROCON
  • 1998 DODGE RAM
  • V8
  • 4WD
  • MANUAL
  • 274,000 MILES
My truck was running fine, except for a leak in the exhaust manifold only when cold, until one day on my way to work I started losing power a little bit. Then on my way home I lost power so bad I couldn't get out of third gear and exhaust was blowing out of the exhaust manifold big time. Now I have fixed the exhaust manifold, replaced timing chain and sprockets, changed spark plugs and wires, changed thermostat and done almost every diagnostic test in the book and now I am stumped
Friday, March 20th, 2009 AT 8:59 PM
BMRFIXIT
  • 19,053 POSTS
Check and make sure converter OK disconnect the O2 sensors and drive it if better suspect bad sensor if not remove the o2 sensor and drive if better cat no good if not check fuel pressure. this guide can help as well
https://www.2carpros.com/articles/engine-stalls
Friday, March 20th, 2009 AT 9:07 PM
BROCON
Yeah I finally had a brainwave and unbolted the exhaust header before the catilityc converter and it fired up like nothing. Thanks for your reply
Sunday, March 22nd, 2009 AT 12:21 AM
Related Engine Stall While Driving Content
