I bought my dodge ram about 3000 miles ago. The bonehead before me put orange coolant in it so i flushed it manually about a week ago. Now I have a problem with it leaking entire reservoir of coolant after running for a bit. It seems to only leak after the thermostat has had time to open up and now my heat won't work, probably due to not enough coolant. don't know what the problem is its not leaking from any of the hoses that i can see. i just look under the truck and it is dripping off the center of the engine. I was told it may be the water pump. Where should i start.
Mar 30, 2008 at 6:44 PM
